Straight Pipe or Flow Pro
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Okay so I just purchased my 85 firebird with a 305 HO a few days ago, and am planning on getting the exhaust done right away. I am either going to
a) Take the catalytic converter off and go straight pipe
b) Take the catalytic converter off and go with a Flow Pro muffler.
Could anyone give me the estimations on the gains I would get horsepower wise?
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Straight Pipe or Flow Pro
not that much. and its illegal either way buddy. i guess if i had a choice id put the fake converter there so at least visually you'll look okay..now unless they check the #'s on it...
Well actually, I am from Canada, and it isn't illegal here, the worst I can get is a $90 noise ticket. Also I am mostly curious about which one will give me the biggest increase. I know it wont be much but I would still like to know.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
straight pipe will give the most "increase", but its still negligible at best. Unless the cat is clogged. Perhaps pickup a aftermarket hi flow cat? it will keep the car from smelling bad, and wont cost much if any power. you most likely wont feel any difference in performance between a straight pipe there, and a high flow car.
the most increase you will notice from the exhaust would be to swap out the stock exhaust manifolds and y-pipe to aftermarket headers and y-pipe. You will most likely feel this change.
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
my friends z28 was like that it was pretty loud and popped like crazy you need to have some back pressure or you could accualy lose power.
I was thinking that but wasn't sure, so basically the Flow Pro would be the better option then.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I would defiently have some sort of muffler.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
straight shot classic cherry bomb put where the cat goes, then straight pipe out the back, no axle loop.
BumpaD82
Feb 26, 2016 02:57 PM
86CamaroDan
Sep 29, 2015 10:08 PM
toronto formula
Sep 10, 2015 07:31 AM
