STOCK MANIFOLD LEAK ON PASS. SIDE
Subscribe
Oct 4, 2010 | 10:57 PM
so , is there supposed to be a gasket there ? im talking about the passengers side exhaust manifold on a 88 LO3 , the drivers side goes all the the way to the to the Y-pipe , whereas the pass. side has a small mettal piece that goes between the manifold and the flange " becayse the manifold just cuts off and has no taper for the flange . any help would be nice
Reply 0
Oct 4, 2010 | 11:29 PM
Re: STOCK MANIFOLD LEAK ON PASS. SIDE
Technically it's a cast iron spacer with tabs to keep it between the two manifold studs. Walker 31533 is supposed to be a service replacement, but if at all possible you'd be further ahead to reuse the stock cast iron spacer.
Reply 0
Oct 4, 2010 | 11:37 PM
so ... no gasket just nuts and studs should be real tight "not to the point of being stripped obviously . " ?
Reply 0
Oct 5, 2010 | 12:32 AM
Assuming you have the correct cast iron spacer, there's no gaskets needed.
The TBI manifolds are the same as the old carbed manifolds. On the old carbed cars, GM used a vacuum operated flapper valve to help the engine heat up faster on hot days. When they did away with the valve, they had to use a spacer to make up the difference. The Walker part number I posted earlier is what you use if you've lost the spacer. It's just a donut gasket that's flat on one side and tapered on the other. But technically it's not nearly as thick as the correct spacer.
That's the spacer from a HO car, the TBI spacer is about the same, just slightly smaller diameter. The other side has the taper that mates up to the Y pipe.
Reply 0
Oct 5, 2010 | 12:39 AM
correct ! , only the drivers side taper meets up with the Y-pipe and the pass. side does not . i still have the iron spacer , so it shouldnt leak right , because i have smoke in my engine bay due to this leak . and the noise does not help when trying to adjust valves .
Reply 0
Subscribe
