drivers side 02 sensor 1 on LS1 swap
Old Aug 10, 2015 | 12:47 PM
timonator's Avatar
I have my engine and trans mounted and the drivers side 02 sensor in the exhaust manifold is broken off and it appears that there isn not enough room for one. Will one fit in there ? Or is there a different solution to this ?
Old Aug 10, 2015 | 07:45 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Re: drivers side 02 sensor 1 on LS1 swap
When i did my exhaust i had the same issue, it wasnt broken off but there just wasnt enough room for it. I ended up having to cap the factory o2 ports and put in new o2 bungs a little lower down the line. I did it on both sides and was good to go.
Old Aug 10, 2015 | 09:16 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
When I had stock manifolds i was able to slightly bend the o2 sensor tail end just enough for it to fit on the driverside and not break the sensor.The passenger side I had to weld a bung on just past the collector in the y pipe i had made up.
Old Aug 11, 2015 | 09:56 PM
timonator's Avatar
What did you use to make a y pipe?
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
