True Duals clarification
Old Oct 29, 2010 | 12:23 PM
Moe87's Avatar
Pictures of my cars underside: http://smg.photobucket.com/albums/v3...aust%20system/
From headers to dual cats, then a Y pipe single to muffler.
Headers==dual cats>-----muffler<==dual exhaust
Because of the dual cats, does that not mean i could run a single pipe from each cat legally or because it goes to a y pipe, it would still be illegal to go true duals?
And how does the physics work behind an X pipe: Would having separate exhaust pipes for each header be better than converging into an X pipe?
passenger header---cat---muffler---tailpipe
driver header-------cat---muffler---tailpipe
OR
passenger header---cat\_____/muffler---tailpipe
_____________________X pipe
driver header-------cat/_____\muffler---tailpipe
I read about how an x pipe smooths out idle and evens the exhaust notes. i also read that when installing an x pipe, you need to place it in the right location to benefit from it over it being detrimental.
"One way to tell where to put center point of the X or install the H, is to take high temp spray paint and put a light coating on each pipe. Driver the car to get the pipes hot, then look for where the paint is bubbling off.....that's where it goes!"
Old Oct 29, 2010 | 01:13 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: True Duals clarification
Almost certainly you can do anything you want after the cats. The easiest mod is to put the X-pipe right where the two pipes join after the cats then run single pipes to two mufflers.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
