long tube headers
Old Aug 21, 2011 | 10:34 AM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
long tube headers
what do are you guys running.
how did they fit, how much of a PITA to install and how much did they cost.
also i heard of some exhaust that is oval instead of round.
all info is welcome
Old Aug 21, 2011 | 05:12 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: long tube headers
I won't be the smartass that says search
Headman 68460's with a T5. Passenger was easy- pulled the starter, went right in. Drivers- disconnected drivers side engine mount, and the transmission mount. Used a jack w/ block of wood to raise the engine on that side. Removed slave and oil filter. Then had to grind on the bellhousings slave bracket to get them to bolt up so I could bend the collector down to clear the slave. I have to bend the collector down to clear the slave now. Haven't had time to get that done yet, and connect the X pipe so I can calculate clearance for mufflers.
Old Aug 21, 2011 | 07:05 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I will.
Old Aug 21, 2011 | 08:33 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Originally Posted by RS Chris
I will.
Man your to cool. Thanks
morrow
Jan 13, 2024 12:29 PM
italiano67
Dec 11, 2016 09:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
