Headman Long tube Headers, and exhaust advice.
Old Aug 22, 2011 | 08:09 AM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Just installed my new 383 stroker motor. Waiting for my Headman long tubes to be delivered. Any advice or suggestions on what to do for a Y pipe and muffler. I want to run 3" all the way back. Any advice or suggestions is appreciated, and yes I've done searches...
Thank you,
Old Aug 22, 2011 | 11:44 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: Headman Long tube Headers, and exhaust advice.
do you want true duals or a single system? plan on trying to work a cat in there somewhere?
Old Aug 22, 2011 | 07:40 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Thank you,
Let me know how those long tubes fit. I was going to do long tubes and 3 in out the side right before the back tires but I don't think a muffler will fit.
Old Aug 22, 2011 | 08:25 PM
Screamin86's Avatar
Imo the side exits aren't a smart idea for these cars its been done but always clerance issues. I had the hedman longtubes on my 82 trans am and my 86 and both fit great the lowest part was my y pipe right where it went under the transmission crossmember same when I ran true duals dumped.
Old Aug 28, 2011 | 10:40 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
did you have to pull the motor to get them in or do any mods. the new springs i put in actulay gave me a couple more inches
Old Aug 28, 2011 | 02:13 PM
Screamin86's Avatar
makes it easier to unbolt motor mounts and just lift the motor a couple of inches. once you do that they drop right in.
Old Aug 28, 2011 | 02:49 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
cool wich part number did you get
Old Aug 29, 2011 | 07:29 AM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Out of the Summit catalog 68460. 1 5/8 and 3" collectors. They went in from the bottom really easily. Literally in a few minutes. The car is on a lift, no starter installed yet, didn't have to unbolt or lift the engine. Stock starter will fit. Welded in a bung on the Collector/Reducer for the O2 censor easily as well. This way if we screwed up, it's cheaper to replace the reducer than the header. Passenger side is clear of any obstructions, have to get a different oil dipstick. Drivers side is close to the frame, a little persuasion with a pry bar took care of that, and have to trim a corner off the A-arm mount, just a slight touch.
Being in Michigan, we don't have emissions testing so I'm not running a cat. or air pump. I'm ordering a Flowmaster Y collector from Summit, 2.25 primary and 3" outlet. A couple of 2.25 mandral U bends and a 3" cat back and I'm good to go. So I'm fabing my own Y pipe. I'm surprised there's no "off road" Y pipe out there for long tube headers for our cars.
Hopefully I'll have it running by weeks end.
Old Aug 29, 2011 | 11:01 AM
mark 87gta's Avatar
Car: 87 trans am gta
Engine: 355 ci
Axle/Gears: 327 for now work in progress
i got the hedman long tubes on my trans am they fit pretty good for the price had to gring the k-member a bit on the left side then i just bought a universal 3 inch x pipe from jegs had a friend weld it and do some bedning with 2 chamber flowmasters ground clearance is pretty good theres a sound clip on my post im trying to seel her
Old Aug 29, 2011 | 10:52 PM
Screamin86's Avatar
I'm surprised so many have clerance issues with the a arm area I had my headers on two diff cars then a friend put them on his and had no issues.
Old Sep 5, 2011 | 02:31 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
maybe different heads????
Old Sep 5, 2011 | 02:51 PM
Screamin86's Avatar
idk i ran mine on stock casting heads and by friend had world heads and had no issues.
Old Sep 5, 2011 | 02:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The reason there are no good LT y-pipes is just because tehre's no way to route them without horribly compromising ground clearance.
Measure from the ground to your crossmember, and subtract the diameter of your pipe you want to use and you will get an idea. There's just no room to run it. Oval piping is the only real solution, but that's SO expensive.
I've got LT's and my setup looks like this thanks you a trick crossmember and my T56
This is what it looked like before with dual 3's at stock height:
It did sound REAL good though.
I am running GM heads and stock engine mounts, and this is where I had to trim the A-arm perch
Old Sep 5, 2011 | 03:06 PM
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
This is what I just made for my long tubes
Attached Thumbnails Headman Long tube Headers, and exhaust advice.-img_20110904_214325-1-.jpg-ex4.jpg   Headman Long tube Headers, and exhaust advice.-img_20110904_154044-1-.jpg-ex2.jpg   Headman Long tube Headers, and exhaust advice.-img_20110904_154031-1-.jpg-ex3.jpg
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
