custom exhaust?
Old Aug 28, 2011 | 01:15 AM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
custom exhaust?
im looking to, when i get the money, to do a dual exhaust that come out below the doors. kinda like what ford did on their older gt500. but i want the flat tip, like you see alot of 3rd and 4th gens have. cutting part of the lower panel and getting it flush with the car, right as the real wheel grove starts. would there be a way to do this? if not could there be an explanation? i dont even know why i cant do a true dual exhaust with out making it custom. and incite would be awesome.
Old Aug 28, 2011 | 03:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: custom exhaust?
jack up the car and look at the underside, you shoudl be able to see why it has top be custom. As for exiting the pipe before the wheels, your not going to have much ground clearance at all, and you really can get the pipe up and intot he rocker because the control arm mounts and "frame" are in the way. Thats why you dont see it done this way.
there are no good dual kits simply because the routing is difficult. Its possible, and many people have dual setups here. there is little advantage to a dual setup other than sounds anyway. especially on a LO3...
Old Aug 31, 2011 | 03:37 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: custom exhaust?
what he said imo duals are the worst choice for a street driven thirdgen ive been there and done that night mare lol.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
ericjon262
Sep 11, 2015 06:07 PM
Ranbo108
Sep 9, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
