Stock Y-Pipe
Stock Y-Pipe
I swapped out the 305 tpi for an 84 Vette engine with a carb, I kept the tpi's exhaust headers and I just tried to fit up the stock Y pipe, but it seems the oil pan is in the way!! Not having the tpi motor to see if the oil pans are different, has anyone else run into this problem? Looks like I'll have to add about an 1" to 1 1/2" to the legs close to the exhaust manifold to make it work,
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Stock Y-Pipe
The F-body cars motors were slightly different than the Vette motors. I'm glad you figured out the difference! Now you'll just need a shop to fab up an exhaust for you!
Genopsyde
Oct 7, 2015 08:35 PM
hectre13
Sep 8, 2015 03:38 PM
