How to Measure Header Primary tubes on car
Car: 1988 Camaro
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 373
What the best way to figure out what size primarys when the headers are on the car?? They are SLP w air tubes not sure if 1 3/4 or 1 5/8.
Engine: 4++,350 & 305 CIs
Re: How to Measure Header Primary tubes on car
Use calipers on a strait part of the header tube.
quick way to tell is the collectors the 1 3/4 uses 2 bolts and the 1 5/8s use 4bolts.
I have a set of both styles of headers, 1 3/4 an the 1 5/8s.. they both use the same size tubing.. SLPs dirty lil secret..
Car: 1988 Camaro
Engine: 383
Axle/Gears: 373
Thats intresting.....mine have 2 bolts. so I just that they 1 3/4
I also got their dual cat conversion to would you might know the size????
If i remember correctly its 2"1/2 outside dia. soo its a bit bit smaller than it should be..
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yup. they are on my 2 sets.
Car: 1988 Camaro
Engine: 383
Axle/Gears: 373
Called SLP this morning......The guy must have not had his coffee bc he was kind of a dick. He said to just measure the primary and nothing about the same sizes or the 2 bolt or four bolt flange.
dumb question.... what should Inter-diamiter be, if you have any idea????
just post a pic of your headers and Ill tell you what you have.
Car: 1988 Camaro
Engine: 383
Axle/Gears: 373
I will in a few days....My sis has the camera. But was looking for id for the primarys
misread your post. the inner dia is smaller than outer dia by whatever the metal thickness is.
It would b hard 4 me to measure it without the proper tools, which I dont have in my garage..
1992 Trans Am
May 10, 2023 07:19 PM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
