Exhaust leak between manifold/head
Old Jan 9, 2012 | 03:36 PM
DizzTransAm's Avatar
Car: '83 & '84 T/As
Yup determined my leak is coming from between the two, any hints on making this easy? Possibly part number for a good manifold gasket?
Old Jan 9, 2012 | 07:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Exhaust leak between manifold/head
spray all of your bolts down the night before with pb blaster,then again before you take em off. use a breaker bar too
Old Jan 9, 2012 | 09:35 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I had a gas leak between the manifold and head on the drivers side closest to the fire wall. I tightened down the bolt closest to the leek and fixed the problem.
Old Jan 10, 2012 | 08:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
after tearing through too many paper gaskets (partially due to a cheap set of shorties), i went with a set of the copper gaskets and never had to do the job again. a lot of guys will also recommend the percy aluminum ones as well, very good pieces
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
