4" inlet muffler
Old Feb 21, 2012 | 05:09 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
4" inlet muffler
what are my options for a 4" muffler? i need to go a little bigger than what ive got. i have a 3" in 3" out 80 series. i like the look of the dual exhaust but i need a 4". i was looking at the borla mufflers but they dont have a dual like the 80 series. i just wanted to see what you guys thought im sure somebody has been through this before. ideally it would be designed like the 80 series muffler 4" inlet 3" or 3 1/2" outlets. thanks for any help i appreciate it
Old Feb 23, 2012 | 09:42 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: 4" inlet muffler
This is what I used.
4" inlet and single 4" out
http://www.summitracing.com/parts/FLO-54033-12/
Old Feb 23, 2012 | 10:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
IF you want a 4" inlet, dual 3" outlet cross flow type muffler like the flow 80 series.....look up spintech mufflers. Its the same muffler used in the mufflex 4" kit. I dont recall the part number but they should still make it I believe
Old Feb 24, 2012 | 01:03 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Look through Mufflex's catalog at the F-body section and see what they have. That's most of what is available.
4 inch pipes are LOUD. I would consider trying to use some diesel/SUV/Truck muffler. I've got a 3.5 pipe with a dynatech splitflow, sounds amazing but it's sooo loud. Im thinking about switching over to a Flowmaster 50 or a Hooker Aerochamber, but I dont think the aerochamber is made in 4 inch inlets. The 50 Im not sure about either.
Getting a dual-out crossflow setup is gonna be tough. I think spintech is the only option... it's the only one Im aware of.
Old Feb 24, 2012 | 07:28 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
sounds good ill take a look at the spintechs. how are those in comparison to the 80 series for sound?
FormulasOnly
Jul 23, 2018 08:47 AM
bplessy
Sep 30, 2015 12:14 PM
