Exhaust Rattle?
Old Mar 9, 2012 | 03:27 PM
TVIROCZ's Avatar
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
Exhaust Rattle?
Yesterday was a nice day so I decided to take my camaro out. I was driving all day and I had no probelms. When it came time to put it in the garage I started it up and I hear this loud rattle coming from the middle of the car. My friend said it sounded like the exhaust was rattling. I had this car since Oct and I never heard that noise before. Earlier in the day I had two of my friends in the car dunno with all the weight maybe I hit something now I am getting a rattle. I started it today and it was doing the samething. Once again it sounds like its coming from the middle of the car.
Old Mar 9, 2012 | 03:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Exhaust Rattle?
Jack the car up, crawl under, do a visual along with some pawing around.
JamesC
Old Mar 9, 2012 | 06:19 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Exhaust Rattle?
If you cant find the cause while your under there try making a ball out of aluminum foil and tuck it snugly between the cat and the top shield/shield and bottom of the car.Then give it a test.Don't push it to far because this is just to see if the shield is causing the problem.
Old Mar 9, 2012 | 06:28 PM
ares88iroc's Avatar
Car: 1988 IROC-Z Camaro
Engine: 355 TPI
Axle/Gears: BW 9 Bolt 2.77 Posi
Re: Exhaust Rattle?
Maybe it's your muffler? The plate things inside my muffler came loose and now they occasionally rattle like crazy. It helped a lot when I took some heat proof insulation and jammed it between the top of the muffler and the muffler heat shield.
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
david068513
Sep 18, 2015 10:36 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
