O2 sensor
Old Apr 10, 2012 | 06:16 PM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
O2 sensor
Where is the stock O2 sensor located on an 85 IROC? The PO installed what looks like home made headers and put the O2 sensor bung on the tube for #5 cylinder right below the turn from horizontal to vertical (if I measured this with a string, it would probably be 4 - 5 linear inches from the port on the head).
Old Apr 10, 2012 | 10:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: O2 sensor
In the driver side manifold.
Old Apr 11, 2012 | 05:51 AM
jminton's Avatar
Car: 1985 IROC
Re: O2 sensor
Is there a location that would be better than where the PO put it? Down at the end just before the ypipe seems like a better place but if I could put it in the ypipe right in front of the cat that would seem ideal (and a little easier for me) .
Old Apr 11, 2012 | 01:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: O2 sensor
you can move it down further, but you may need to switch to a heated sensor in order to get it to read properly
Old Apr 11, 2012 | 03:40 PM
jminton's Avatar
Car: 1985 IROC
Re: O2 sensor
alright, thanks.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
