Need help with exhaust bolt part #'s and location
Old Apr 13, 2012 | 01:34 PM
philly5eagle's Avatar
I have a 91 305 TPI. Stock manifolds.
The motor came in pieces when we bought it so I'm doing my best to put it back together stock for my son.
I was looking for a set of exhaust manifold bolts. The ones that bolt to the head.
Locally, Autozone had a Dorman set part # 03401. Book shows they go to this vehicle. However, there are four regular bolts and 2 that are like a bolt but the have threads on the other end of the bolts which I assume it to attach something else to. I can't figure out which ones go in which holes in the manifold. In addition, on the drivers side, the last hole in the manifold is shorter than the other holes, so all of the bolts are too long for that hole.
Does anyone know if I have the correct bolt set and if not which one should I be using.
In addition, if anyone has pictures of the manifolds installed on both sides, maybe I can see which holes get which bolts. Any help is appreciated.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
