th400 and headers
Old Mar 14, 2013 | 01:15 AM
nowerelsetoroam's Avatar
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
th400 and headers
Just got my 355 running and its awesome.
But I know its dying from those stock manifolds.
So headers are going on no.matter what.
Problem is I have a th400. And it has those bigger flaps
On side. I would love long tubes but I'm.guessing.I would already have
Fitment issues with the stock k member then the trans after.
I have looked at shortys into the y pipe. But I just want that more
Power from the long tubes.
Has anyone ever installed long.tubes with a th400 and find there way around it?
Old Mar 14, 2013 | 09:10 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: th400 and headers
Unless your over 500hp ish you wont really gain much from longtubes vs shorties like dyno dons.
If you just have to have longtubs, you can cut off the flaps on the trans, I have done many of them.
What are you doing with this car?
Old Mar 14, 2013 | 09:33 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Cut the ears off. But you still will have tight clearances around xmember for ypipe to hook up. If car is lowered there will be ground clearance issues.
Old Mar 14, 2013 | 12:55 PM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Well the car is just going to be driven on.weekends
To cruise meets and some track time as well.
The cars not lowered. I want it to remain stock.height.
Rite now I'm not near 500hp. My goal is atleast get 400 Hp
At the wheel and il be happy
Old Mar 14, 2013 | 07:56 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
everybody has exhaust issues with long tubes because you have to come below the frame. ive got a th400 and long tubes but i just left it open, but ive been wanting to put an exhaust on it. ive changed the conversion crossmember so it sits back further (welded new mounts). i think im going to cut the frame were the exhaust is going to go and weld in supports were i cut it out. i already have sub frame connectors.
Old Mar 15, 2013 | 12:56 AM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Dang sounds like Im gona have to stick.to.shortys.
There still better then the Stock manifolds.
I.guess il save the long tubes and headache for my ls later on
Old Mar 15, 2013 | 07:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Dyno don shortys are about as good as you can get. More than enough for 500 hp, its been proven. I would contact him
Old Mar 18, 2013 | 08:22 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
you will have to cut the ears off the trans. Also I made another crossmember for the 400 that way you can run longtubes and duels without cutting the frame. The pipe will get close to the trans but it will work.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
