Headers 2055 and cat and Borla cat back
Subscribe
Apr 5, 2013 | 05:11 PM
I read the sticky on the 2055's and I plan on buying the following, based on the advice there. Do I need all of this? Do I need anything else? I don't plan on doing the install myself. Money is not an issue, so I'm not looking for cheaper alternatives.
Borla 1984-92 Camaro/Firebird 3'' Dia. Cat-Back System
5.0L/5.7L
Adjustable Sound/Performance Level
Split Rear Exit
Dual
Part Number: 157-14888
$765.99 Remove
Magnaflow3'' In/Out Catalytic Converter
Part Number: 642-94309 $107.99 Remove
Red Boot Guards, 8/pkg
Part Number: 555-40302 $46.99 Remove
Hooker Headers CERAMIC CAMARO 86-90
Part Number: 520-2055-1 $702.99 Remove
Mr. Gasket STARTER MOTOR HEAT SHIELD
Part Number: 720-3678 $22.99 Remove
Mr. Gasket S/P WIRE BRKT 87-UP
Part Number: 720-6042 $44.99 Remove
90* Wire Set Super Cond. SB Chevy w/HEI Cap
Part Number: 121-35599 $82.99 Remove
COPPER CORE SHORT PLUG 4
Part Number: 111-0276S-4 $16.99 Remove
Reply 0
Apr 5, 2013 | 07:42 PM
Re: Headers 2055 and cat and Borla cat back
Without chasing each of your PNs across the internet, you don't need boot protectors, there's lots of room atleast on my 2055s, plus you're getting ceramic. 90 degree boots are neccessary, most plugs are short enough, Accel and ACDelco seem to be the exceptions. If that's the hard aluminum starter shield it may not work with your starter, has to have vertically oriented screws on the end of the motor, mine didn't. I didn't bracket my plug wires but that's more for aesthetics anyway. You will need to buy or make a shorty/header spark plug socket, I didn't have to take any length but I cut a slot about a 1/5 the diameter of the socket, resembles an O2 socket for plug access. The bolts and gaskets that come with the headers are not the best, many prefer aluminum gaskets, and some type of locking header bolt. If you're keeping the A.I.R. sys you'll probably want to get a couple of the check valves.
Reply 0
Subscribe
