More than 3", really?
Old Apr 9, 2013 | 10:26 PM
Cosmik Debris's Avatar
I'm looking at a new exhaust system for my 400 DFI engine, it has AFR210s and a 240/245@50 .594 lift solid roller. I've seen this rule of thumb "115cfm per square inch of cross-sectional area you need 2.2cfm of flow capacity per horsepower". It shows that you need a lot more than 3" for 500HP and over. Do you really need more than a 3" exhaust?
Cheers
Old Apr 9, 2013 | 10:47 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: More than 3", really?
Uhhhhmmmm, yah, with 500hp, you will need more than 3" of exhaust.
Best to go with a single 4", with 1 3/4 or bigger headers (with 3" collectors)
Old Apr 10, 2013 | 11:30 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Yes, go with a single 4"
Old Apr 10, 2013 | 12:30 PM
Blowtorch79's Avatar
Car: 1989 Formula 350
Engine: 383ci, +150hp N20
Transmission: Built 700R4
Axle/Gears: Moser 9", 3.73 Detroit locker
4" for sure..... and get the Magnaflow if you order from Hawks. It sounds killer.....If you don't mind pissing off the neighbors.
Old Apr 10, 2013 | 03:44 PM
OK thanks, so that rule actually works pretty well. It will have to be a custom build unfortunately, whilst the exchange rate is pretty good at the moment shipping costs to New Zealand are pretty high :-)
