exhaust leak
Old May 9, 2013 | 10:22 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
Transmission: 700r4 with shift kit
Axle/Gears: stock gearing
exhaust leak
is it normal for an exhaust to only make the ticking noise just while driving and not at idle or in park or nuetrel while revving the engine cause i have a strange tick that sounds like an exhaust leak that follows my rpms while driving but when its in park or neutrel and i rev the motor it doesnt do it. i also recently installed the bosch III 22lb injectors and heard they are known for ticking but i didnt think it would be ticking like this, any info would help greatly
Old May 9, 2013 | 11:55 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: exhaust leak
If your exhaust is leaking, try to identify where. If you get down to ground level, you should be able to spot where the leak is by the "sputtering" sound a leaky exhaust makes. Does it sound like it's coming from the engine bay? If so, check for carbon deposits somewhere around your exhaust/exhaust manifold to help identify the leak. A leak should be fairly easy to see if you can get under the car. If you can't find one, I'd look elsewhere for that ticking noise.
Old May 10, 2013 | 09:37 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: exhaust leak
I have a very similar exhaust leak when some header bolts came loose.
Sounded like a tick or almost a miss. Tightened the manifold bolts and problem solved.
Old May 10, 2013 | 04:48 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
Re: exhaust leak
i thought it may be the manifold bolts coming loose. ill tighten them up and see if that helps
Old May 12, 2013 | 11:08 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
Re: exhaust leak
taking my car to the shop tomorrow to have my new muffler put on and ill have them check for leaks. and to make sure my manifold bolts are all tightened
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
