True 2.5" Mandrel Bent Duals
Old Jul 9, 2013 | 06:32 PM
Z28/ZR1's Avatar
Thought I'd share my fabricated exhaust system.
All 2.5" mandrel bent stainless 304, including hangers and flanges.
Also incorporated a cross over in order to enhance the torque and achieve a mellow tone.
Mufflers are Magnaflow Polished Bullets.
Tips are 3" stainless.
Old Jul 9, 2013 | 07:14 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: True 2.5" Mandrel Bent Duals
Very cool!
Old Jul 9, 2013 | 07:17 PM
Twin_Turbo's Avatar
Very very nice indeed
Old Jul 9, 2013 | 07:34 PM
ghost91's Avatar
Car: 1991 Camaro Z28
Very nice work from front to back!
Old Jul 9, 2013 | 09:17 PM
Z28/ZR1's Avatar
Thanks guys.
It's still a 5.7 ltr. with lots of internal and external goodies.
Old Jul 9, 2013 | 10:04 PM
mjds's Avatar
Car: 86 sport coup
Engine: room for rent looking for ls power
Transmission: t-5
very nice, looks like great ground clearance too!
Old Jul 10, 2013 | 02:23 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
OMG, IT'S SO CLEAN UNDERNEATH! Needs LCAs though.
Old Jul 10, 2013 | 08:08 AM
skinny z's Avatar
This IS nice work.
It's back to the shop for me. I assembled a y-pipe years back with stainless bends but didn't go so far as duals. Just a merge collector and an aftermarket cat-back setup.
What headers are you using?
Did you have to modify the cross member?
I don't suppose there might be a sound clip of the exhaust note?
Attached Thumbnails True 2.5" Mandrel Bent Duals-100_1843.jpg   True 2.5" Mandrel Bent Duals-100_1896.jpg
Old Jul 10, 2013 | 08:13 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
awesome work!!! great pics too!
Old Jul 10, 2013 | 08:20 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
That is beautiful. Nice job. Such a clean car.
Old Jul 10, 2013 | 09:45 AM
Z28/ZR1's Avatar
Originally Posted by skinny z
This IS nice work.
Headers are Hooker shorties. Yes, I did have to modify the tranny support. Welded a flat steel plate across the section where the material was removed.
Don't have a sound clip yet, as I have been working on her in stages. Engine, exhaust and now the interior. Being that quality and loudness of sound is a personal preference, I have to say that for me, the sound matches the car perfectly. I went with the LT4 hot cam, so the slight lope is distinctly noticeable, which is what I wanted.
Old Jul 10, 2013 | 09:59 AM
skinny z's Avatar
I think modifying the cross member is the only alternative if reasonable ground clearance is to be expected. (That's my cross member in the picture I posted) The automatic transmission doesn't make it any easier either. I know there are aftermarket alternatives too.
From a performance standpoint, unless you were to run a massive single bullet race muffler (spelled LOUD) duals are the way to go in order to achieve enough cfm.
Sound, or loudness, is a personal thing as you mentioned. I'm still looking for a combination of flow and something that doesn't wake the neighbors.
Again, excellent looking job. I wouldn't doubt that I'll follow it as a pattern for the next exhaust system that goes on my car.
Old Jul 10, 2013 | 10:16 AM
Z28/ZR1's Avatar
My cross over served several purposes. 1. It balances the pulses for added torque. 2. It served to mellow the sound, as the same I.D pipe was used. 3. Also served as a structural re-enforcer for the Y pipe, which then connects to the dual pipes (minimizing any vibration)
Old Jul 10, 2013 | 10:24 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The exhaust looks great, but out of curiosity, why did you put the crossover where you did, instead of just incorporating an x a little farther back where the two pipes pair up? You would have been able to make a little more horsepower with the "x" instead of the "H" style pipe, plus it seems like it would have been a lot easier to incorporate it where the pipes are closer together.
Old Jul 10, 2013 | 10:34 AM
Z28/ZR1's Avatar
Ideally, you want to put the crossover where the greatest amount of heat is generated. The reason I went with the "H" style verses the "X" had more to do with sound. I have tested both H and X styles and the gain differences haven't been that drastic, so, in this case sound tone was more important.
Old Jul 11, 2013 | 09:24 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Nice job and thanks for sharing! Getting ready to instal the Dynomax kit #89009, true daul 2.25". I will try and get some photos etc and post them. Thanks for the motivation and nice work.
Roy
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
