Dual sidepipe?
Old Aug 31, 2013 | 10:19 AM
MeanFbirdT/A's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: LG4 305
Transmission: Borg-Warner T5
Dual sidepipe?
I was wondering If I could run longtube headers, high flow cats, into staight pipes that bend out right infront of the rear wheels. Would that sound good and be possible?
Old Sep 29, 2013 | 09:56 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Dual sidepipe?
it's probably possible and I think it would sound pretty good, but there isn't a lot of ground clearance so...
Old Oct 7, 2013 | 04:18 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
Re: Dual sidepipe?
I wanted to do that but put flow delta flow 40s in there also I dont know how it would look though
Old Oct 29, 2013 | 11:50 AM
Navy8125's Avatar
Re: Dual sidepipe?
I just got my car last month and it came with dual side pipes right in front of the rear tires. There is hardly any clearance at all. I grind over any speedbump no matter what angle I take it. I also grind whenever I don't see a pot hole. They look cool and sound good, but you will eventually just tear them up with no ground clearance. I have it in the shop this week to have them re-routed to the rear sadly.
Old Dec 7, 2013 | 05:02 PM
blackpaint's Avatar
Car: 1991 formula firebird
Engine: 5.0
Transmission: automatic
Re: Dual sidepipe?
hello meanfbird,i just read your thread on those side pipes. i had bought a 91 formula back in the spring and dumped a lot some of cash in it ( just a hobby) and was thinking abouit putting a set of side pipes on it. people says it cant be done.as you know anything can be done. what i was wondering was how loud they were on your car. sorta stock sounding , a deep sound ? and if they was a good tight fit. just courious your the first i came across with this type exhaust
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
