True Duals
Car: 1989 Chevy Camaro RS
Engine: V6 2.8L
True Duals
Im looking to put true duals on my 1989 Camaro RS. Is it possible? I have been told it is not because the driver side sits to low. Has anyone done true duals?
Car: 1983 Z28
Engine: 385 Fastburn
Re: True Duals
I have true duals on my '83 Z28. It's totally possibly and the only time I have clearance issues is with REALLY high speed bumps. I have true dual 2.5" pipes all the way from the longtube headers to the mufflers (which dump right before the rear axle.)
here are some pics
here are some pics
Car: 1983 Z28
Re: True Duals
My pipes could be bent a little better to give even more room too.
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: True Duals
It can be done but how hard or easy depends on your set up. I have a SBC with a TH 400 trans using an UMI torque arm crossmember. Not easy.
Manual transmissions and newer automatics using factory crossmembers. Easier.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: True Duals
With an auto, from everything I've read says its nigh impossible but doable with a manual. With an auto you need to route it so it follows the factory single tube routing.
Car: 1983 Z28
Re: True Duals
I wouldn't say impossible, the pipes just can't be put in the same spot as with a manual. I have a TH350
