SLP Header y pipe exhaust gasket part number
Old May 2, 2014 | 03:55 AM
IBrockZ's Avatar
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
So for those of who are looking for a replacement part number for the SLP Header y pipe exhaust gasket I spent this afternoon trying to to find the correct replacement exhaust gasket for the y pipe
This is the part number I will be using for my SLP Header y pipe replacement exhaust gasket for me my install:
EG24057
The brand is called ROL Gaskets
They were $1.49 each and I bought two to replace my old worn out stock SLP y pipe exhaust gaskets.
Hopefully this info is convenient for someone else because I had to spend a portion of the afternoon trying to source up a part number after being unsuccessful at finding this part number on here.
Old May 2, 2014 | 07:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: SLP Header y pipe exhaust gasket part number
You mean the 2.25" donut gaskets? Not a very uncommon part to find.
Old May 2, 2014 | 08:22 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its a normal parts house 2 1/4 -2 1/2 doughnut gasket. Almost any brand will work.
ROL was sold to another company or has closed shop so any gaskets from them you get are old stock.
Now if you want a challenge, find the gaskets for the tri-Y header collector/Y pipe.
Old May 2, 2014 | 08:37 PM
IBrockZ's Avatar
Engine: 305 tpi
The ones I purchases were 2.5 inch that's what fits into my SLP y pipe as far as I can tell haven't installed them yet will be installing the y pipe and wrapping up tonight. It's not that it was super hard to find the right gasket it was just a lil time consuming figured I'd share a part number just in case some one wanted to search the board rather than trying to find the part that will work in the stores. As for the company going out of business hopefully who ever bought them out will use the same part number but I doubt it lol.
Old May 5, 2014 | 06:22 AM
It's the stock donut for a lot of big blocks.
Any parts store will have it; ask for something like, a 76 Suburban 454. Should get the right thing.
Brand doesn't too much matter. AutoZone has em in FelPro for example.
Comes in 3 flavors: all-metal (which is what I prefer), all-composition, or composition with metal cladding on one side.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
