Exhaust Question-- Cat Size
Old Oct 5, 2014 | 11:20 PM
Zink57's Avatar
Car: 1987 IROC Z
Engine: LB9
Transmission: 700-4R
Guys
I was wondering what performance difference in terms of HP would I be looking at if I replace a converter with the 2.5 inch (inlet/outlet) with a 3 inch Hi-Flow cat. The rest of the exhaust system is stock 3 inch thru Magnaflow mufflers.
By the LOOKS alone it looks restrictive at the cat and the welding looks kind of "sloppy"... will there be any noticable difference in drivability if I were to get the larger cat converter? The IROC doesn't have headers. AND will the lower back pressure (if any) change the EGR functionality. I live in CA and get a little paranoid regarding the SMOG ****.
much appreciated in advance.
Old Oct 8, 2014 | 02:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Exhaust Question-- Cat Size
Maybe get you you a few HP's and ft/lb's...don't expect ground breaking results
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
ambainb
Aug 29, 2015 12:43 AM
Out-Cast
Aug 22, 2015 07:49 PM
knight72
Aug 10, 2015 09:32 PM
