new exhaust header gaskets
Old Mar 22, 2015 | 08:53 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
ok so I installed exhaust header gaskets and I go to start the car up and im still getting a leak im wondering if the headers are warped or if the gaskets aren't just sealing correctly im using felpro exhaust manifold gaskets im wondering if I should get copper gaskets and see if those will work better
Old Mar 23, 2015 | 10:17 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: new exhaust header gaskets
copper gaskets are good . prep & torque sequence is VITAL . first make sure surfaces that mate to block are smooth and flat . IMPORTANT , tighten from the center outward . tighten 2 center , then 2 inboard on front & rear pipes , then 2 out board on front and rear pipes . then go back and re-torque in same sequence . repeat torque sequence several times . start run engine , cool down , re-torque follow sequence above . do this several times , IMPORTANT , follow above sequence . did I mention its IMPORTANT to follow above sequence ??? good luck ..............
Old Mar 24, 2015 | 07:52 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have had a ton of luck with these when felpro would not seal.
http://www.summitracing.com/parts/ph...make/chevrolet
Old Mar 26, 2015 | 11:40 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I use the Percey's crushable gaskets. 5 years and no leak so far...lol I just jinxed myself.
1992 Trans Am
May 10, 2023 07:19 PM
tom1985
Apr 19, 2016 07:55 AM
hectre13
Sep 8, 2015 03:38 PM
formula_novice
Sep 5, 2015 03:58 AM
ambainb
Aug 29, 2015 12:43 AM
