Hooker 2055 Leak at Y-pipe
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
Hello,
I finally got around to installing the Hooker 2055 with AIR pipes and I have a leak between the driver side header and Y-pipe. After struggling with it for awhile I took it to my shop's exhaust people and they said the y-pipe is not bent properly and is not reaching the header sufficiently.
I haven't read of anyone having this problem. The gap is very small and I am curious if I could use an exhaust donut to bridge the gap. I was hoping that I somehow installed it wrong. Suggestions?
I didn't have my camera on me. Next time I drive it to work I'll throw it on the lift and snap some.
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Re: Hooker 2055 Leak at Y-pipe
You could try loosening all the bolts and tighten the leaking side first... maybe use some thicker aluminum gaskets. I ALWAYS use red gasket maker on headers, put it liberally on the gaskets at both ends... I have had header bolts almost fall out- and no header leaks this way.
The last leak I've had was when the aluminum actually deformed...
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Axle/Gears: posi
Aluminum deforming? Damn!
Just to be clear, my leak is from the y-pipe to header connection. You're suggesting that I use a thicker gasket at the header to head connection and that'll help realign my y-pipe to header connection?
I'm willing to give anything a try. I would have pictures, but one of my calipers has seized. So, now I have to fix that before I can drive it to work and lift it up for some pictures. I'm also going to attempt to fix the leak altogether.
no green
Jan 9, 2016 09:22 PM
