Help needed
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Help needed
Ok working on my 92 rs
All I have is two jack stands and a hydrolic jack.
How can I get the rear end up high enough to snake the intermediate pipe in?
Car: `86 SS / `87 SS
Re: Help needed
lift the pumpkin
set the rear housing axle tubes on jackstands
set the jack on stacked wood
lift the pumpkin
set the rear housing axle tubes on jackstands on top of wood
you get the idea
lift the pumpkin
you get the idea
Re: Help needed
Might wanna just put the car up as high as you can get it, support with jack stands under the chassis (let the rear end hang), take off the wheels, unbolt the little brake line junction from the pumpkin, jack the rear back up acoupla inches, take the bottom shock bolt loose on each side, let it hang down as far as it will go, and let the springs fall out.
RAYS87TURBO
South Central
Sep 5, 2018 07:27 PM
AmpleUnicorn88
Interior Parts Wanted
Nov 2, 2015 09:33 PM
