over the axle pipe clearnace
Old Mar 29, 2016 | 09:26 PM
BOTTLEDZ28's Avatar
Transmission: A4
How much clearance should there be for the 3" pipe that goes over the rear axle? I am in the middle of installing a Magnaflow catback system on my 91 which needs slight modifications at the ypipe area. The cars factory catback is long gone and so is the factory flange after the cats so I have to make a custom pipe to bridge the gap. I just need to know what a good amount of clearance is for the pipe going over the axle.
The car is lowered with the Eibach Pro kit.
This is what I currently have for clearance.
Just not sure how far up the axle moves during suspension travel.
Old Mar 30, 2016 | 09:09 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: over the axle pipe clearnace
Looks can be deceiving but it looks like you have more clearance than my 3" pipe.
If it were me, I would unbolt the shocks and remove the springs. Jack the housing up to the stops to verify clearance.
It would drive me crazy having the exhaust hitting over bumps.
Old Apr 2, 2016 | 01:03 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Yeah, what he said and the bump stops do compress a bit too. Put the axle to the bump stops and still give it 3/4" to a inch of space in between the two or more if you can.
someone972
Apr 5, 2016 06:23 PM
BOTTLEDZ28
Mar 17, 2016 07:23 PM
tractorguy
Exterior Parts Wanted
Mar 7, 2016 04:42 AM
Jokersall
Mar 5, 2016 09:19 PM
gt4373
Mar 1, 2016 11:10 PM
