Heat Shielding with Hooker 2055s
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
I'm concerned about heat transfer from the Hooker 2055s to the starter and brake lines. I have <1" of clearance in some areas (even after bending the brake lines out of the way). Thinking of using something like this:
https://www.summitracing.com/parts/hsp-721202
I had planned on cutting a piece to fit over the starter and wrapping small slices around the brake lines near the headers. Anyone done something similar, and how did it work for you? I know ceramic coating would be the ideal solution but I don't have that kind of money. Also, lots of debate on wrapping headers vs shielding heat sensitive parts; I think I would prefer to shield at-risk parts based on what I've read.
As always, appreciate any input!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Heat Shielding with Hooker 2055s
Just an FYI: In the decade or so that I've been running the Hookers, I've experienced no issues with starter or lines.
JamesC
JamesC
Car: '91 Camaro Z28
Engine: L31 5.7
Thank you for the feedback JamesC.
Mind if I ask if you're running the stock starter? And how much clearance you have on the lines?
Car: '91 Camaro Z28
Engine: L31 5.7
That's definitely reassuring, I was thinking anything less than an inch would too close.
Thanks again!
Thanks again!
[Sold] Hooker Exhaust System
dmorse1
Apr 2, 2016 02:45 PM
89TA WS6
Apr 1, 2016 09:40 PM
ray jr
Mar 31, 2016 09:26 PM
