Trouble with shorty headers and stroker oil pan
Old Dec 28, 2016 | 10:08 AM
ChozenZ28's Avatar
Car: 1986 iroc-z
Engine: SBC 406
Transmission: T5 awaiting T56
Axle/Gears: Stock
So, I'm really not seeing a way possible for the exhaust shop to be able to make a y-pipe for me. Has anyone ran in to this problem and if so what was your end result. Has anyone used shorty headers with stroker pan. Need help so close to being done and now this.
Old Dec 28, 2016 | 10:10 AM
ChozenZ28's Avatar
Car: 1986 iroc-z
Engine: SBC 406
Axle/Gears: Stock
Re: Trouble with shorty headers and stroker oil pan
Have a couple more pictures if needed.
Old Dec 28, 2016 | 10:16 AM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
Silly question, but is that one the correct one for that side? it looks like it might be better suited on the passengers side.....
Old Dec 28, 2016 | 10:40 AM
Twin_Turbo's Avatar
It's the correct one. Normally the Y pipe runs in front of the sump but that pan is like the moroso pan. Either you end up with a clumsy restrictive bend or you can do one of 2 things. One is buy new headers the other is cutting the crossmember and welding in a section of large diameter tube. This so you get a curved in clearance for the front if the Y pipe to lay in flat.
Here's the same issue. Oirked but not well. Chinese stainless longtubes fixed this.
Old Dec 28, 2016 | 10:45 AM
Twin_Turbo's Avatar
These are 2 setups. One with crappy edelbrock headers one with hedmans. I never completed the hedmans. It was the same if not worse than the edelbrocks.
Attached Thumbnails Trouble with shorty headers and stroker oil pan-6227840238312372402.jpg   Trouble with shorty headers and stroker oil pan-6219211060830587074.jpg   Trouble with shorty headers and stroker oil pan-6219211062399853890.jpg
Old Dec 28, 2016 | 11:22 AM
ChozenZ28's Avatar
Car: 1986 iroc-z
Engine: SBC 406
Axle/Gears: Stock
Thanks for the reply, was the K- member cut in to on those pictures? And if I was to cut in to the K-member and box it in would I lose any strength?
Old Dec 28, 2016 | 12:04 PM
Twin_Turbo's Avatar
Not cut. I swapped headers. No wou wont loose strength if done properly. In fact it might be a little stronger even
Old Dec 28, 2016 | 04:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Could you cut the collector off and angle it a bit more forward?%;
