Finely i got the smog
Old Feb 25, 2017 | 09:26 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
Tonight i finely got the smog pump off (lighter than i thought it would be) and those smog hoses, all thats left is weld on the o2 bung put on the new headers then go to the muffler shop
Old Feb 25, 2017 | 09:57 PM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Re: Finely i got the smog
Did you get the smaller belt? Or did you get the pulley kit? Removing my cats next weekend as well as removing the smog pump. O2 sensor stays where it is. How hard was it to remove the smog pump and hoses?
Old Feb 25, 2017 | 10:12 PM
SketchyZed's Avatar
Engine: 5.7
For the belt i got part number 968k6, i just looked at https://www.thirdgen.org/forums/atta...ltrouting2.gif
The smog pump and hoses wren't too hard the thing that got us was a stripped torx bolt
Old Feb 26, 2017 | 08:36 AM
Yeah GM had a torx fetish on the TPI engines, you need a good set of torx heads so you don't strip them (Husky is really good)
