What is name of this piece on exhaust manifold?
Old Jul 30, 2017 | 12:30 PM
metalhead1's Avatar
The black piece that threads onto the shiny piece. Mine broke off at threads.
Attached Thumbnails What is name of this piece on exhaust manifold?-manifold.png
Old Jul 30, 2017 | 12:34 PM
Re: What is name of this piece on exhaust manifold?
Check valve
A "pneumatic diode ", if you will.
It allows fresh air to go into the exhaust, but prevents exhaust from backing up into the AIR pump.
Old Jul 30, 2017 | 12:37 PM
metalhead1's Avatar
Hmm, with engine running, I can hear and feel exhaust popping out of it. Also, can't seem to locate on sites like Advance and Autozone.
Old Jul 30, 2017 | 12:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.rockauto.com/en/catalog/...eck+valve,4912
Old Jul 30, 2017 | 01:02 PM
metalhead1's Avatar
Thanks Tuned, that is perfect! And after further review, I am going to need the piece that it threads onto. That is what has threads broke off, but the valve has the broken threads in it, impossible to remove.
Old Jul 30, 2017 | 01:09 PM
Engine: Lb9
Transmission: M20
I looked up 1990 you might want to double check they should be the same.
https://www.rockauto.com/en/catalog/...tion+pipe,4904
Use a line wrench and pb blaster to help remove the air tubes from the manifold.
Old Jul 30, 2017 | 01:11 PM
metalhead1's Avatar
Yea, I just found that too. Thanks for your help!!
