Backfire or rattling?
Old Jan 3, 2002 | 01:35 AM
youcrash's Avatar
I have 3inch piping with flowmasters for exhaust, not sure if it is CAT back or not.
The engine size is the v6, on the 1987 base line model.
Sometimes when I shift around 3k RPM I hear a load pop, not quite as loud as your normal backfire and there is no smoke.
Any ideas to what the problem could be? my friend tells me its just my exhaust rattling but it sounds like more and usually only happens around 3k RPM.
Thanks.
Old Jan 3, 2002 | 02:20 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well, a rattle and a pop are 2 different sounds. Flows are know to make a popping noise upon letting off the gas. However, it could be a backfire, do you have an exhaust leak? And, how come you have 3" piping on a V6?
Old Jan 3, 2002 | 03:15 AM
youcrash's Avatar
When I bought the car it came with 3inch piping and the flowmaster, with dual tips.
I am not sure if I have an exhaust leak or not... not quite sure how to check.
When I shift I let off the gas so it must just be the flowmaster.
Old Jan 3, 2002 | 03:34 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
well one way I found a few exhaust leaks on my car was to let the motor soak in ATF over night
started it up and let it ran for a while
trust me that stuff smoked for like 15 min after I did it
though I do have a diff engine design then you guys but I am sure you can still get it to work
for the most part if you have a leak you will se white smoke just pouring out like crazy
if you do this I would say watch out how much you put in dont want to hyrdolock anything
Old Jan 3, 2002 | 03:46 AM
Car: 99 Formula
Axle/Gears: 342
An exhaust leak sounds like a ticking noise, I'm sure one to cause a backfire would definately be noticable, and it's directly related to engine rpm.
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Racerx974
Sep 19, 2015 10:16 AM
Ian Irvine
Sep 4, 2015 08:08 AM
