Anybody know the part # for the gasket needed between the passenger side spacer and manifold. Or if there is even one that is supposed to be there. Thanks in advance.
The flange between the manifold and the spacer is flat on both parts. With only two studs holding the flange together, any issue is going to cause a leak.
