90 RS 305 Muffler/exhaust advice
Old Nov 3, 2017 | 11:45 AM
mlacek's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
After replacing a fuel pump on my 90 RS 305 TBI Camaro (had to drop the tank), I damaged the muffler fitting, so am looking to replace my dual exhaust muffler. I would just get the OEM style, but wanted to check with you guys on what you'd recommend. I am currently running it without the muffler and dual pipes that connect to it, and it sounds awesome. But probably not the best permanent solution. Should I just get a stock muffler/tailpipe setup, or is there a slightly better bolt-on upgrade you'd recommend?
Old Nov 3, 2017 | 11:47 AM
mlacek's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Re: 90 RS 305 Muffler/exhaust advice
Here’s a picture showing why I am replacing...
Old Nov 3, 2017 | 02:10 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
What do you want? Something stock? Something louder? There are a dozen or so options out there. You might want to go with walker if you need something stock.
Old Nov 3, 2017 | 02:14 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
DynoMax Cat Back is about as cheap as you can go, especially when they have their annual rebate..
