A.I.R. tube nut size???
Car: 1990 Trans Am
Engine: 383 stroker
What size are the nuts that screws the air tubes into the exhaust manifolds, 15mm seems too big and might strip and 9/16 won't fit. What size is it? Please help! It's a 350 TPI L98.
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: A.I.R. tube nut size???
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
They are actually 1/2" - 20 straight threads, I use some 1/2"-20 alan head set screws to block them off, but 1/4" NPT plugs will work (the tapered thread is the same but will bind up in the threads when you get it threaded in far enough)
