shorty header installation
Old Jan 17, 2002 | 10:43 AM
TBI305Camaro's Avatar
i have a set of hooker comp shorties and i wanted to ask has anyone been able to install the right side headers without unbolting the motor mount and raising the engine with a board underneath the oil pan...do i have to do this? also how hard would it be to install motor mounts? just do that then put new ones in? id say if i have to do that its probably about time for motor mounts anyways so i might go ahead and do that
Old Jan 17, 2002 | 10:47 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I got mine in on both sides without leaning the engine.
Old Jan 17, 2002 | 10:49 AM
how long did it take you and what kinda headers did you use?
Old Jan 17, 2002 | 11:05 AM
Mark305TBI's Avatar
My dad and I completed the install in a weekend. We didn't rush or spend an incredible number of hours on it on any one day. If you were in a hurry I'm sure that you could get through the process faster than we did.
I used Dynomax Street-Series shorties with the AIR tubes cut off and the holes welded shut.
Old Jan 17, 2002 | 11:20 AM
anything i should watch out for while doing the install? think i could get it done in one full day?
Old Jan 17, 2002 | 12:00 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
bwahahahaha.... no, really, it'll go very smoothly, guaranteed.
If you have a competent helper and all the parts you need, definitely.
As far as the psgr side header, jack the car up a foot or two and drop the starter/solenoid (it's very easy, trust me). I haven't installed Hookers, but I'll bet you can get them in from below by doing this (I'm not making any guarantee, but this has worked for me and others). If you have A/C, good luck getting it in from above.
Old Jan 17, 2002 | 12:34 PM
i used to have AC but not anymore...i think i can get the passenger side in from the top and ive replaced the starter thats simple...the drivers side is the side i think i might have some trouble installing...we will see im sure itll be fun anyways
Old Jan 17, 2002 | 01:12 PM
Mark305TBI's Avatar
To get the driver's side header in you have to pull a bolt out of the steering colum that runs right past the engine. When you take the bolt out it'll pull apart and you can push it out of the way to allow the header to drop in. Once it's in you can push it back where it goes and put the bolt back in.
Old Jan 17, 2002 | 02:17 PM
Car: 91 Formula
Engine: 305 TBI
Sorry, I thought you ment psgr side by "right" side (I was thinking from the wrong angle).
On the driver's side, I also had to take the valve cover off (in add'n to what Mark said) to get it to fit.
Reddeath210
Oct 6, 2015 08:20 AM
Wesly_66
Aug 26, 2015 09:55 PM
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
