Brodix 11x
Old Apr 5, 2022 | 05:04 AM
onebdgti's Avatar
Brodix 11x
I have a set of Brodix 11x heads and need ideas for headers. Are the adapters really worth using or is is better to get new headers or fabricate my own?
Old Apr 5, 2022 | 06:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Brodix 11x
If you have the ability, fabbing your own header starting with the actual stahl pattern flange would be ideal. Is it the spread port version or standard port?
but i guess it depends on what you are doing and if you have a set of headers. If standard port and have a set of headers, and not an all out race mill, maybe adapters are good idea, as long as you have room to space header out 3/8”. If you need like 1 7/8 headers or something more custom spec for a race deal, make your own
Old Apr 6, 2022 | 04:48 AM
onebdgti's Avatar
Re: Brodix 11x
They are the actual spread port flange. I am still on the fence of using these heads. Something tells me to go ahead and the other side says nope.
formula88
Feb 25, 2001 05:47 PM
