Long tube headers and exhaust combo!
Old May 10, 2022 | 06:37 PM
BigRoc23's Avatar
Car: 1990 Iroc
I have a 90 Iroc with the 350 auto. I soon am swapping it with a T56 through hawks motorsports. I was wondering the best Long tube headers for the car, I really only care about sound and making sure it’ll fit with the t56 or if that isn’t even a problem. Also should I just straight pipe it? Or get a certain muffler? I am pretty knew you cars and am still in high school so any help would be appreciated!
Old May 10, 2022 | 07:27 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: Long tube headers and exhaust combo!
Hooker 2210 long tubes.
If you're gonna go with true dual you might want to invest in a Blackheart crossmember. It's made for an LS swap but folks have had success using it with a 350. Makes routing the exhaust much easier.
https://www.holley.com/products/engi...ts/71222005HKR
I've got the 2210s using a home made y-pipe to a 4 inch single pipe to a flowmaster so I can't speak to a dual setup.
Good luck.
Old May 10, 2022 | 07:34 PM
BajaDaze's Avatar
Car: 1989 IROC vert UMI sus w/1LE brakes
Engine: 1990 ZR1 LT 5, alum flywheel
Transmission: Tick built T56
Axle/Gears: 3.7 Borg Warner
I'm running the Hooker BlackHeart 2.5" true dual exhaust with the newer Hawks T56 crossmember with plenty of clearance
Old May 10, 2022 | 08:02 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You should absolutely straight pipe your first car so you'll be set up for the rest of your life to never do such a dumb thing again.
Old May 11, 2022 | 08:05 AM
BigRoc23's Avatar
Car: 1990 Iroc
so I should or not? It’s a yes or no question
Old May 11, 2022 | 11:46 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
No, you'll most likely end up hating it and/or getting in some kind of trouble with a local noise ordinance everytime you leave for school at 6:30 am or whatever.
Old May 11, 2022 | 04:09 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
What’s the budget? What do you want the exhaust pipes to do in the rear? Single outlet? Dual outlet? Turn downs? Chrome tips?
Cheapest would be eBay long tubes and y pipe with a 3” single exhaust, used if you can find it to save money.
The full Hooker Blackheart dual setup with matching headers, exhaust, and trans crossmember is over $2k.
bjankuski
May 27, 2012 07:39 AM
smokefan
Apr 4, 2006 09:40 PM
colonboy14
Sep 12, 2003 08:57 AM
jamesbob02
Nov 3, 2002 11:09 PM
