banging out the cat...help!
Old Jan 30, 2002 | 03:12 PM
Dan94GT's Avatar
how do you bang out the cat? I'm trying and having some difficulty. what should I expect the stuff coming out to look like? what's the easiest way?
Old Jan 30, 2002 | 05:46 PM
Boosted GTA's Avatar
take off the cat, get a long screw driver, or a broom stick, stab the cat, you will see a metal screen thingy come out along with black pellets. Once u're done, just put er back on.
Old Jan 30, 2002 | 06:20 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
better yet just have a straight pipe put in. lot better gains and sound from a straight pipe
cost you maybe 40-60 bucks
and also if they ever pass smog in your area you still have you cat so you dont have to go out and buy a new one
Old Jan 30, 2002 | 06:55 PM
Dan94GT's Avatar
well I just took off the one end of the pipe. the other had a u-bolt and I know those never come apart and back together again. Im almost done. theres 2chunks that wont break up small enough to come out. and there is no metal screen and pellets. its like a light weight ceramic material with tiny holes all the way through.
Old Jan 30, 2002 | 07:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You must have a monolithic cat then... They flow better then the older bed type but now that its gutted i dont think it really matters
Old Feb 1, 2002 | 03:54 PM
WS6 Berlinetta's Avatar
I've had to use a hammer and a long metal spike to break monolithic cats, a broom won't do much here. Just think of it like having to break a chunk of old cement into small pieces.
R
Old Feb 3, 2002 | 06:41 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I used a piece of steel rebar on mine but you would be better off just adding a hi-flow cat to it, it will sound better than a gutted cat and make more power also, a gutted cat causes a lot of turbulence unless you add a pipe inside it. I gutted mine when it went out and it sounded awful but after I put a good cat on it, I had more power and it sounded much better.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Ghettobird52
Apr 21, 2020 08:44 PM
mustangman65_79
Apr 14, 2017 05:37 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
