cat
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
cat
hey i have a gutted cat and i need to pass emisions is there anything i can do besides egt another cat or dumb alcohal in mt tank to pass? alsi the little tube on the side it broke i guess its called the A.I.R or sumtin. would havin a hole right there help me pass at all caus i am losin some exhaust? please help i don't wunna buy a 60 doller cat just to use for emisions
Transmission: 4L80E/4L80E
Buy a high-flow cat with A.I.R. tube. You'll probably need an A.I.R. repair kit as well (provides a high-temp rubber hose & clamps to allow you to hook the A.I.R. tube back up to the cat). Leave it in there after you pass.
Car: 89 Formula
Engine: Carbed 5.7
wut is a good cat to buy and will any high flow cat let me pass emissions? also were would i get this A.I.R. reapir kit
Catco is probably the best deal going as far as value. If you want the best, Random Technologies makes the best :\ flowing cat plus it's all stainless steel (the catco is aluminized steel with stainless heat shield).
I picked up the repair kit at Checker. Midas put one on my mother-in-laws Caprice several years ago. Should be able to get it from most any parts store or muffler shop.
LT1Formula
Oct 8, 2015 08:34 PM
