Clogged Cat?
Old Mar 2, 2002 | 09:48 AM
Buck268's Avatar
Clogged Cat?
There wouldnt happen to be a way to check fer a clogged cat w/o removing either the imtermediate pipe, the y-pipe or both, is there?
Old Mar 3, 2002 | 09:49 AM
Nasty_Bird_'90's Avatar
why do you think its clogged? if you a) lost a lot of power all of a sudden, or b) can feel almost no exhaust pressure coming out of the tailpipes, then chances are you need a new cat. those are the only ways i know to check without taking stuff apart. a few weeks back,i lost all power. the car would bog down. i also had a hissing noise (kinda sounded like a turbo!!) coming from the back of the car. no tailpipe pressure. put in a new cat, and voila!!! power is back, but i lost the turbo sound
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
