ok, i just got my Hedman headers and Y pipe for my 84 TA, they didnt come with a O2 sensor, and i was wondering where would be the best place to get it welded in on the headers or the Y pipe?
On the drivers side header at the collector is the best place for the least amount of work.
The best place is on the y-pipe after the two pipes merge. But then you'll have to extend the wiring in addition to changing to a heated OČ sensor and adding the wiring needed for that.
wouldnt the placement mess with the ratio though? if i put it to far up, ill run too lean, and to far down to rich??...ill porbly just run it on the Y pipe right after the collector
