i think my cat is clogged....please help
Old Mar 18, 2002 | 09:16 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok when i floor my car it still has low end torque but it has NO upper RPM HP....it just doesnt pull at all....and it barely goes up to 4000.......the belt snapped on my smog pump a couple months ago.....and i heard that if you try and just take off the belt on the smog pump it will clog the cat.......is this true?
if so....do you think mine is bad?
thanks!
Old Mar 18, 2002 | 09:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is your cat glowing, is the car running warmer than normal.
Old Mar 18, 2002 | 09:25 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well my car always runs hot so i couldnt tell you.....but how long will it take for my cat to glow?
Old Mar 18, 2002 | 11:25 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I've read you are supposed to remove the o2 sensor, start up the car, and see if it revs better, if it does, clogged cat.
If I were you, I'd just replace the thing, it probably has some age and miles on it, get a high flow, or none at all
Old Mar 18, 2002 | 11:31 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
https://www.thirdgen.org/techbb2/sho...threadid=92553
thats what i would do if i were you
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
