Going from dual cats to single hi-flow, thoughts?
Old Apr 3, 2002 | 03:03 PM
sIcK pUpPy's Avatar
I 'm looking at gettin' blownbird's SLP set-up. I have a 5.7L with factory 2 cat exhaust. I'm kickin' myself in the butt for askin' this question, but this will improve my exhaust flow, right? My concern was going to the single cat configuration over the duals I have now.
Thanks in advance,
JD
Old Apr 3, 2002 | 03:57 PM
Momar's Avatar
I havnt heard of someone swapping it that way before, but I think if what you have is stock then yes it will flow better. However, I think that the aftermarket dual cat setup with dual high flow cats might be even better but Im not sure about that. That system is 3 inch right. I know that 3 inch is supposed to support quite a bit of power.
Ben
Old Apr 3, 2002 | 04:01 PM
sIcK pUpPy's Avatar
The main reasonfor this swap, is because i have a hellacious leak in my dual cat Y-pipe that can't be repaired because it's between the pipes that run parallel. I ran over a bear at 75 mph (see my post on the exhaust board for a full expanation). The whole situation kinda sucks, but I would like to get the headers.
JD
Old Apr 3, 2002 | 04:24 PM
91L98Z28's Avatar
Car: Z28
See this thread:
https://www.thirdgen.org/techbb2/sho...threadid=96549
Long and short of it, according to random tech, is that two of their 2.25" converters will flow 600cfm+ whereas one of their 3" converters will flow around 500cfm.
The problem of course is that the manifold to cat pipes will have to be custom made.
In the long run, I don't know what's better... an SLP Y-pipe with a single 3" cat, or stock manifold-cat pipe with the twin 2.25" converters.
Old Apr 4, 2002 | 12:26 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I'll tell ya what's better!! No cat at all!! lol.....
I would get that system he has up for sale and just slap a straight pipe in place of that converter and call it a day. That'll flow better than your current setup.
Old Apr 4, 2002 | 07:18 AM
Momar's Avatar
Thats what I'd do, but I dont know about your emissions laws.
Old Apr 4, 2002 | 12:22 PM
sIcK pUpPy's Avatar
Unfortunately, we have emmisions out here. But I am thinking about fabbing up an off-raod pipe to replace the dual cat setup if I don't hear back from blownbird. I haven't herd from him yet, so we'll just have to see. The track opens up on the 13th, so i'm gettin kinda antsy.
Thanks guys,
JD
Jorlain
Oct 8, 2015 01:57 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
