California Smog Woes
Old Apr 13, 2002 | 11:32 PM
batmanta01's Avatar
Car: 91 GTA, 95 T/A, 80 FIREBIRD
Engine: 350, 350, 305
Transmission: 700R4, T-56, TURBO 350
For anyone who can help, thank you in advance!!! I just bought an 88 LB9 T/A. I bought the car as is, it runs great! My problem is the previous owner failed the emissions test twice on hydrocarbons at 25 MPH. I figure an oil change, cap, rotor, and new wires will help, any suggestions? Or anyone had this problem before? I already changed the oil and added a fuel additive.
Old Apr 14, 2002 | 02:04 AM
ORAY777's Avatar
Might be the catalytic convertor or could be the smog pump air thermactor stuff isn't working properly. Get a haynes manual to diagnose some of those areas and if you can't take it to a shop and just get a diagnostic. But i think it's the catalytic convertor. How many miles?
Old Apr 14, 2002 | 10:18 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Just take it in for a tune up and tell the mechanic that it has failed the smog test and they usually know what to check. It could also be the EGR valve.
Old Apr 16, 2002 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I doubt it's the EGR valve. That typically affects NOx.
The cat may be the problem. A cheaper possibility is the O2 sensor. Replace it when you do the plugs.
Another possibility is a leaking injector (the fuel additive may help if that's what it is).
The fact that it only failed at 25 MPH is interesting, but the above 3 could do it.
Old Apr 17, 2002 | 11:28 PM
Pony_killer1's Avatar
Im goin in for smog this weekend..keeping my fingers crossed.....
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
