[PA] PBR rear caliper brackets
Old Feb 7, 2019 | 01:40 PM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Looking for a pair of rear caliper brackets for a PBR disc brake setup. My slide pins are seized and need new brackets.
Old Feb 7, 2019 | 02:12 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: PBR rear caliper brackets
there's a guy on Portland oregon craigslist who posts these once in a while (apparently he does new and used?)....if one of the members here isn't able to help,you may want to check it out or post a want to buy (WTB) ad etc.
Old Feb 7, 2019 | 02:19 PM
Car: 85 Berlinetta
Thanks. I can get one through Rockauto at a decent price but they only have one. Just seeing if someone has a couple laying around they don't need.
Thanks for the info.
Old Feb 7, 2019 | 05:17 PM
Drew's Avatar
The caliper carrier is cast iron, or steel. Heat and penetrating oil. Tap the pins with a hammer lightly to setup vibration, keep oiling and heating, eventually the pins should break loose. Then get yourself a wire bore brush (.45 should be close) from the gun cleaning section of your local Walmart, chuck it in your favorite cordless drill, run it in and out of the carrier and watch the rusty gunk flow out. Clean, run your bore brush, clean, run your brush, clean... When you've got it all cleaned up, use new pins and plenty of good grease, make sure the seals are seated, good 2 go.
zman1969
Aug 7, 2018 12:27 PM
greezemonkey
Apr 16, 2016 01:55 PM
MY-92-RS
May 26, 2014 11:10 PM
IROC212
Brakes
102
Feb 20, 2003 12:32 AM
