Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Miller TIG welder choices?
Old Feb 28, 2004 | 07:41 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I am planning on purchasing a Miller AC/DC TIG welder. I am looking at something between 180-250 amps. I was looking at new models but i will consider a used model as well. What are the better Miller models to get based on features?
Old Feb 28, 2004 | 07:47 PM
Engine: 4.0L
To add to my question, I have seen Miler models advertised like Syncrowave, Maxstar, Dynasty, Bobcat, Trailblazer and Econotig. These are all advertised as TIG machines, I'm assuming that the Syncowave is the better of the three right?
Old Feb 28, 2004 | 09:27 PM
ede's Avatar
ede
bobcat and trailblazer are engine driven portables. syncowave is the best to me for an eletric machine. look at machines with very simple control panels, less you have to set or adjust the less mistakes you can make.
Old Mar 3, 2004 | 11:11 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I've got a Syncrowave 250 here, and it's more of a machine then I am a welder. It is a liquid cooled unit that's classified as an industrial duty machine, and is actually rated to 310 amp output. The big advantage of the Syncrowave series is the variable AC balance control which is used when welding aluminum. What you should get mainly depends upon your welding requirements and how much you're looking to spend. If you're only doing light fabrication, general repairs and hobby type stuff, you really don't need a liquid cooled unit. In that case you might want to consider the Syncrowave 180 SD package (includes everything but a bottle, helmet and welding rods), as long as it meets your amperage requirements. The Econotig is a good bang for the buck AC/DC package, but is limited to only 160 amp output. Forget about the Maxstar series (DC only). The Dynasty and Aerowave series are very advanced liquid cooled professional level TIG welders ($$$).
Old Mar 4, 2004 | 02:07 AM
Engine: 4.0L
Thanks Mike. I am looking at some Syncrowave 180's right now. They are in my price range even new. I wouldn't mind finding a used unit that someone is selling to upgrade though to save a little money.
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
ericjon262
Sep 11, 2015 06:07 PM
mrdevontay
Sep 2, 2015 08:04 PM
