Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
lincoln mig welder 100/115v owners out there
Old Apr 5, 2004 | 11:02 PM
jester111's Avatar
Hi
anyone outhere with this welder, do you find that the 0.6mm/.023 number wire burns hotter and penetrates better than using the .030 in this machine. By the way its converted to gas.
thanks
Old Apr 10, 2004 | 09:01 PM
Xhiron's Avatar
Car: traded away 94 v6
Engine: vacant
Transmission: also vacant
What model are you referring to? I have a MIG Pak 15 (the bigger one) and I like the .030 flux cored wire, generates the deepest welds but splatteres like a *****. The thinner .023 wire makes some nice deep welds, but at a price of higher consumption of wire.
Old Apr 11, 2004 | 07:01 AM
ede's Avatar
ede
penetraion is usually the same as the wire diameter. the wire speed controls the heat output. unless you're over heating the base metal there should be no noticable differance between .023 and .030 other than .030 taking more power to run, which may be the reason you think you have less penetration.
Lbibb
May 5, 2016 12:00 AM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
