Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
New fuel injection works!
Old Nov 12, 2004 | 01:51 AM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
Big marathon of hooking stuff up.
Cranked the engine lots of times with no results.
Remembered that the tach and V+ for the distributor were disconnected, so I hooked them up.
1 second worth of cranking later, it fired right up, timing was right on, idled like perfect... more news later, it is 3am and I am supposed to do the work thing tomorrow...
Specs:
All homebrew except for the sensors and manifold base, which was for a carb. Commander 950 Pro, WBO2, 42lb injectors, intank 255lph pump
Old Nov 12, 2004 | 09:34 AM
oil pan 4's Avatar
Car: 89 Firebird
I like the way you operate.
Old Nov 13, 2004 | 09:33 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Is that a twin TB? Or just two small horns on a regular TB? Too cool looking. Can you show a pic without the airhorns on it?
Old Nov 13, 2004 | 12:37 PM
Guss_B's Avatar
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
All the colours of the rainbow
Old Nov 13, 2004 | 04:42 PM
Spifz's Avatar
2.75" throttlebodies (~70mm)
Old Nov 15, 2004 | 12:16 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
That looks freakin Killer! Nice Job!!!
Old Nov 16, 2004 | 06:11 PM
92GTA's Avatar
Looks allot like this...
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
