Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Longtube/t56/crossmember?
Old Dec 16, 2004 | 11:32 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Does anyone know who's car this is? I'd like to mimic their crossmember so I can tuck my LTs up higher. So anyone with measurements, screen names etc, please help.
I posted this in the exhaust section and got no response.
Attached Thumbnails Longtube/t56/crossmember?-ypipe1.jpg
Old Dec 18, 2004 | 02:21 AM
83 Crossfire TA's Avatar
The frame rail that that passenger side header tube is going under is usually one of the lower points on our cars… that setup would have almost no ground clearance at stock ride height.
The driver’s side on the other hand… that is probably better then what most people do with long tubes.
Old Dec 18, 2004 | 02:38 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The passenger side front subframe rail actually angles up at the back. The dirver's side rail is much lower at that point. He probably has as much clearance on the pass. side as he does on the other with that crossmember.
Old Dec 19, 2004 | 03:17 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
It looks like the passenger side sits about an inch lower than the transmission case, it's hard to tell at the angle of the pic. I'm guessing it has pretty good ground clearance the way it is.
Old Dec 25, 2004 | 03:51 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i bought a crossmember from ebay that looked just like that..i cant remember what the guys screen name was but he makes them and sells them on ebay. i think his name was pcperformance or pfcperformance...look into it.
Old Jan 22, 2005 | 10:54 AM
RaGe's Avatar
Car: 1990 Firebird Formula
I bought that exact one from the guy who makes them..
Can"t wait to put it on my car with hedman long tubes... Hope everything fits well.
Old Jan 23, 2005 | 12:43 AM
smokefan's Avatar
yea i would of used it but mine didnt fit cause i have an aftermarket t56 so i went with a different one instead.
Old Feb 8, 2005 | 11:33 AM
german-motorsport's Avatar
iansane.....hahahahah funny you postet you know who he is!????
its 3rd gen member "Drew" and glad he made this on the market before other copycats claim it was there deal!
